RE: micro balloons
I use finish reson with micro ballons. I found epoxy sands hard, like ply. Finish reson sands fairly easy like hard balsa. Either way works. Alcohol on your finger tip can help smooth it to reduce sanding. A mix like toothpaste is about perfect.
Edwin
