RCU Forums - View Single Post - BVM Electra kit finished! EDF 4010
Old 11-05-2009 | 01:20 PM
Bob_B's Avatar
Bob_B
Default RE: BVM Electra kit finished! EDF 4010
Yes the motor is the same, but you may want to double check the controller settings. SET the motor timing to LOW if you plan to run a 4010 on 12S
ORIGINAL: bidrseed2
I know its not what youre asking as my electra is an ARF, but with the 12s 5000 TP extreme V1, mine came in just a smidge under 14lbs.
And if its not quick enough for you on 10s, Ill happily lend you my 12s pack for a flight at classic jets. It would be interesting to see how they 12s TP Version 1 compare to the 40c rated 10s pack.
( I think the 4010 is just the same as the 5012 should still work)
Frank
