ORIGINAL: cgroen
Duncan,
pictures please when you have them
The details4scale controller is rediculous big, it's not possible to switch it on/off using a reciver channel (only the landing lights), so you will either need to have to connect/disconnect the battery or buy a seperate switch for it. And it is not so that there is no room inside the controller box, if just the electronics where designed less than 20 years ago......
Carston,
The Multi Watt lighting system for the Viper Jet now comes with a programmable on/off smart switch.
I wouldn't say the controller is rediculously big. It was designed to handle up to 12 AMPS worth of lights! There's a lot of heat generated by that much power (hence the cooling fan). If the case were smaller, the fan would be of little use. I mean if you can't find room for it in the Viper Jet, somethings wrong...LOL...
Dan
