RCU Forums - View Single Post - k&b 7.5 flex lube ?
Thread
k&b 7.5 flex lube ?
11-06-2009, 06:32 PM
5
ob nut
My Feedback: (
1
RE: k&b 7.5 flex lube ?
Before every run, put the 50/50 mix of 80/90 gear lube / STP oil treatment. When you have the bottom halves apart, drill a hole on the upper mount (where the powerhead contacts the lower). See the pic of the SS motor from K&B. Make large enough to get the mixture in. keep it flowing unti it comes out the bottom holes. I use a Bru Line glue syringe to get the mix into the lower. When done running for the day, shafts come out and are placed in a leak proof container that has the oil mixture in it.
Reply
Like
ob nut
View Public Profile
Send a private message to ob nut
Find More Posts by ob nut
View iTrader Profile
