RCU Forums - View Single Post - Tower Hobbies Uproar 40 build
Old 11-06-2009 | 08:28 PM
mclina's Avatar
mclina
Default RE: Tower Hobbies Uproar 40 build
I gotta ask - did you buy three kits? Or just one and scratch building the other two off the plans?
After building the Dazzler, I was pretty confident that I could scratch build one easily. I saved all of the punched-out sheets to use as templates. I may give it a try later this winter. I bent an identical wire landing gear for a small ugly stick that I scratch-built, so that's no problem. The only other custom piece is really the canopy. The bulkheads should be pretty much just squares without a turtle deck.
Your stick piles are looking great. I can't wait to see the assembly line.
