Very nice work. I screwed my canopy down also in order to get inside. Only downside I see is when the sun hits it, you will notice that the plastic expands and the bottom edge gets a little wavy. But when it cools down it goes back flat. I put a white towel over the canopy when it is sitting out in the sun at the field to sheild the sun. How thick is the landing gear? Mine is home made. 1/8" aluminum. I suspect 3/16 would be better cause mine bends pretty easy. Not bad for me (new flyer) cause it acts like a shock absorber
. Or maybe the grade of aluminum I used isn't the good stuff. Eventually I'll upgrade to the TNT.
