RCU Forums - View Single Post - Golf ball dimples
Old 11-09-2009 | 09:05 AM
  #150
hugger-4641's Avatar
hugger-4641
Default RE: Golf ball dimples
ORIGINAL: dick Hanson
ORIGINAL: hugger-4641
Hypothethical case in point, try to put the wing from an F-14 on a Cessna Citation and see if generates enough lift to fly.
Include the engines from the F14 -yup it works!
Aero rule 1- enough power fixes all other deficiencies-
Your light hearted attempt to dodge the point still supports it If you don't include the F-14 engines, then you will will not get enough speed thus not enough "lift". Therefore, as you alluded in an obscure way in your prior post, any object can create lift if it has enough air (speed) moving past it. But a properly designed airfoil is required for controlled flight of any given craft. I don't think anyone here is lost on that point, unless you really are!
