Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Golf ball dimples >
Golf ball dimples
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Golf ball dimples
Old 02-02-2010 | 04:28 PM
  #226
Default RE: Golf ball dimples
Most if not all of those components can be included in the coefficients A, B and C.
Old 02-02-2010 | 05:36 PM
  #227
rmh's Avatar
rmh
ORIGINAL: Sport_Pilot
BTW if you take time time out of the equasion -all you have is torque.
And you can have torque without movement. which nobody wants for a plane.
actually- an electric motor -which has max torque at ZERO rpm -is a very desireable setup for driving a propeller -
far better than an IC engine when instant performance is req'd
I have flown both types a lot and the IC setup has far more lag in accelerating the prop.
Old 02-05-2010 | 02:57 AM
  #228
Bundubasher's Avatar
If you take 2 identical dimension & weight golf balls - one with and one without dimples, and you hypothetically drop them off a high building i.e 30 storeys high on an absolute calm, windfree day - say onto a concrete pad below - which ball will bounch back quicker and which one will bounch higher.....?
Old 02-05-2010 | 09:20 AM
  #229
rmh's Avatar
rmh
Me thinks you changed golf balls in mid stream -so to speak
Old 02-05-2010 | 12:09 PM
  #230
Dimples on golf balls began when it was noted that the older beaten-to-death balls which at the time were covered in leather, if there was lots of surface damage, these balls flew further than brand spanking new smooth balls.
