I run two of those in parallel. Sick speeds and really good run times.
They are a tight fit in the battery compartment, so tie a ribbon (like the one's for X-mas wrapping) around the battery and leave yourself
some tabs to grab to help you pull them out.
You also will need to vent the body and add a heatsink to the Brushless motor to keep it from going thermal.
