ORIGINAL: Jascat100
You do still have to cut about half an inch off the front of the cockpit tub & grind away the excess at the top of the fuz join, to get it to fit with the tanks in this arrangement.
I found that out the other day, its not too bad as it only the top bit of the "tub" directly behind the instrument panel so its not an issue.
Duncan I will be using the bypass, Ali has sent me my turbine mount, so I will attacking that quite soon. If you want to talk about it feel free to give me a ring.
Carsten, you will have plenty of room, if you look up Mark Schro. / Ali's install that will give you some good ideas.
<br type="_moz" />
