RCU Forums - View Single Post - Another Skymaster Viper
Old 11-10-2009 | 11:35 AM
  #399
hangarman's Avatar
hangarman
Default RE: Another Skymaster Viper
ORIGINAL: DENTO
Carsten Thankes for the shots very helpfull
I allso sat my tank on top of intake gave more room I thought ,I move my cockpit tubs forword 80mm to give room for fill plugs and bat charge points don,t have to remove tubs for start up or shut down, The plugs you see take place of the switches , Push in for on, Pull out OFF Then female becomes charge Point.
Craig thanks allso went back a bit and seen your install must of missed it
REGARDS
John
Looks really good! Where did you end up putting your batteries in the nose? Also what batteries did you end up using?
H
