RE: engine question
dave de,
Check all the simple things like the filter in the carb, inline fuel filter which is a much, and is you battery fully charged. Sounds like you just need to tweak on the needles. If it is still a new engine everything else should be ok. I said should. Where your needle are currently is a good starting point but you need to tune the engine properly.
