engine question
Old 11-09-2009 | 06:31 PM
My Feedback: (12)
Default engine question
I,m getting my engine to start, idle & run at half throttle, when at full throttle she quits. I have my hi needle 2 1/4 turns open low needle 1 3/4 open..... from what I,ve read my low end might be rich. I,v tried closing a little at a time. when I do this, do I nead to lean the hi also
Old 11-09-2009 | 07:18 PM
Zippi's Avatar
My Feedback: (10)
Default RE: engine question
dave de,
What engine do you have? Tweak your "H" needle for max rpm and then richen it about a 1/16 of a turn. Start leaning the "L" needle until you loose a good tranistion and then richen it a little. Go back to you "H" needle and repeat.
Old 11-09-2009 | 07:42 PM
My Feedback: (12)
hey, thanks for the reply....I have the 3mm t0c-53 It was running fine then all a sudden this. I,ve been fooling with the needles all day long
Old 11-10-2009 | 09:38 AM
Check the internal carb screen for debris....2-1/2 turns out on the high end seems like a LOT for any gasser. After inspecting and cleaning the screen, tune as Zippy described and report back.
Old 11-10-2009 | 10:30 AM
av8tor1977's Avatar
If the internal carb screen is clean, then check the regulator diaphragm. If it is in the least bit stiff, it needs replaced. If you have a filtered clunk in the fuel tank, you should check that for cleanliness as well.
AV8TOR
Old 11-10-2009 | 11:18 AM
My Feedback: (12)
could the regulator diaphram be bad when the engine is really still in break-in mode........is that the same as the float diaphram
Old 11-10-2009 | 01:08 PM
Zippi's Avatar
My Feedback: (10)
dave de,
Check all the simple things like the filter in the carb, inline fuel filter which is a much, and is you battery fully charged. Sounds like you just need to tweak on the needles. If it is still a new engine everything else should be ok. I said should. Where your needle are currently is a good starting point but you need to tune the engine properly.
