ORIGINAL: hangarman
ORIGINAL: DENTO
Carsten Thankes for the shots very helpfull
I allso sat my tank on top of intake gave more room I thought ,I move my cockpit tubs forword 80mm to give room for fill plugs and bat charge points don,t have to remove tubs for start up or shut down, The plugs you see take place of the switches , Push in for on, Pull out OFF Then female becomes charge Point.
Craig thanks allso went back a bit and seen your install must of missed it
REGARDS
John
Looks really good! Where did you end up putting your batteries in the nose? Also what batteries did you end up using?
H
G-DAY HANGERMAN
Allup the nose 5200 li ion 2 on flight side 2 on ecu with the 160sx need power for kero start with no hangups with power
REGARDS JOHN
