RCU Forums - View Single Post - Kyosho Osmose 70, Sort of build thread (slow..)
Old 11-10-2009 | 05:36 PM
  #121
lojik's Avatar
lojik
Default RE: Kyosho Osmose 70, Sort of build thread (slow..)
ORIGINAL: Thinn
I don't see why you cannot fly the Osmose without the canalizer. If you are not used to flying planes with ''razor-sharp'' rudder responce, I would actually advice you to try without.
Using the canalizer, you hardly have to apply any rudder at all in knife-edge flight, but this also results in a very sensitive rudder during normal flight...
Normally, I fly the ZN Oxalys. Originally, It had a canalizer mounted but I chose not to use it.. I tend to push wrong rudder on too many occations, and using the canalizer would make it way worse than it already is!
Try without the canalizer and post the result here
Thanks Thinn,
I really really like the look of the Osmose without the Canalizer. I will post some pics and maybe a flight video when she is complete.
I have an onboard removable camera I am going to mount on her when she is complete so I should have some nice smooth in-flight footage to show off
the wings are together, just need another 12 hours for the plugs and fill to cure. All of the control surfaces are linked in. No probs so far so she is looking good.
L
ID:	1311810   Click image for larger version
