RCU Forums - View Single Post - A matter of thrust
Old 11-10-2009 | 10:16 PM
  #42
freakingfast
Default RE: A matter of thrust
ORIGINAL: Sport_Pilot
Ever covered the hose (inlet or outlet) on a vacuum cleaner? It speeds up, less load....the impeller blades are stalled.
The fan speed increases because it is not allowed to move air. So a small amount of air recirculates between the blades and around the edge of the fan. The fan increased the pressure on the outlet side and decreases the pressure on the inlet side, the fan blades are now operating in a partial vacuum, even if blocked on the outlet side, so there is less load. It has nothing to do with a stalled condition.
Lots of info, search: stalled axial centrifugal impeller
