RCU Forums - View Single Post - A matter of thrust
Old 11-11-2009 | 01:30 AM
  #47
alfredbmor's Avatar
alfredbmor
Default RE: A matter of thrust
Thanks for your comments guys.
Not really light, it is around 14 pounds, I will recheck the weight with someone else s scale. Manual stats around 12 lbs.
Test flight will be in around 12 days. I do believe that wing loading will help a lot with this particular biplane.
The original ones were powered by a small 4 cylinder engine, they were build with wood, fabric and little metallic sheeting, mostly at front.
Propeller was bigger and I do believe that rpm were low.
ID:	1312152   Click image for larger version
