RCU Forums - View Single Post - Updated Weight Requirements?
Old 11-11-2009 | 07:10 PM
  #181
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: Updated Weight Requirements?
ORIGINAL: 2Sunny
So even though I don't think folks are willing to make a change, and I agree it is possible to make weight today I'd like to bolster Tony's case with a real world example:
I have recently (as in just today) acquired 2 used e-machines, a Beryll and JAS's Argentinian Worlds Integral. That brings my hanger to a total of 3 professionally built, ''state of the art'' 2M machines. All 3 machines are over 11 lbs if I use Rhino packs, and 2 of the machines are over even with the preferred TP Pro Lite V2 5300's. I will have to use TP 4350's to make weight with 2 of the machines or otherwise make expensive alterations of equal or greater cost.
There must be some way to take this into consideration. Maybe provide an ideal battery weight (say the weight of TP Pro Lite V2 4350's), subtract that from 11lbs, and then make the empty weight for e-machines that number. That way batteries that don't weigh the ideal amount (i.e. are cheaper) are not excluded.
Just another 2 cents
JP
I was trying to get at this earlier. When you buy 'professionally built', second-hand e-machines, you are buying the design of the builder. If they had their mind set on using the lightest batteries for competition, then that's what you are stuck with for your battery choice. I think it's extremely important to talk to the people we buy our used airframes from and determine if this is the case. I think the lesson to be learned is to see the plane on a scale before making the decision to buy.
I think it's safe to assume that the guy who bought the brand new, $3300 Beryll probably wasn't thinking of using the cheapest, heaviest batteries on the market to power the plane.
One solution is to have a set of 'competition batteries' to make weight for competing flights, and use the Zippy batteries for practice.
