RCU Forums - View Single Post - engine generated interferance on 2.4
Old 11-12-2009 | 09:50 PM
NM2K
My Feedback: (14)
Default RE: engine generated interferance on 2.4
ORIGINAL: dirtybird
2.4 GHZ is not immune to RFI. However it is much easier for the ignition manufacturer to shield its product at that frequency. Any well made ignition system should cause not RFI on 2.4 GHZ. If you have interference when using 2.4GHZ, I would get rid of that ignition system. It is not well made.
I know someone will say I have this high priced, brand new system and it caused RFI on 2.4GHZ. My answer it is not well made despite its price
It is difficult to generate substantial radiation on 2.4 GHz, especially from a device that wasn't specifically designed to do so. Much more likely is that the R/C system is picking up the 5 KHz > radiation from the ignition system via the R/C system's wiring. Even a 2.4 GHz system can respond to extraneous signals in the audio voice range (and higher) sufficiently to foul the demodulation of the Tx's data.
Ed Cregger
