ORIGINAL: DENTO
ORIGINAL: hangarman
ORIGINAL: DENTO
IF you are going fishing ,You would have heard about the watch chain trick
REGARDS John
No, educate me!
H
<br type="" />
G-DAY HANGERMAN
I cut a 15mm hole across inside the wing from the servo box towards the leading edge forward of the wing tube box allso a 20mm hole in the root rib forward of the wing tube hole then a mt of fine watch chain from BUNNINGS here, lowes over there,Then dropped it through the hole in the servo box hang onto one end hold the wing verticle and the chain will drop through hopefully, BEEN FISHING ,HEY hope you understand all that
REGARDS
JOHN
John,
I see what you mean!! I use a basic method similar to that but cheaper! I use cotton thread with a small nut! I have in the past used with mixed results again with cotton thread,one end has tied / glued a really small piece of cotton wool, use a hoover with a pipe and use the suction to draw it through. (Doing the housework?)
H
