RCU Forums - View Single Post - HELP: Machine Gun and Light not coming on-M26 Pershing
Old 11-15-2009 | 07:56 PM
torpedochief's Avatar
torpedochief
Default RE: HELP: Machine Gun and Light not coming on-M26 Pershing
Hummmm now it could be a low battery. Or maybeyou might just try pulling the crystal from the reciever and reseating it. That might just do the trick.
Another thing to do is to start it up and play withthewires to see if it is a loose connection in the 8 pin. Also check the pins. They could be pulled out just enough that it does not make contact.
If that fails you might have a bad board.
Keep pluggin.. You'll fixi t
Don
