RE: Composite-ARF Integral, kinda build thread
Hi
just started to convert my old Integral to el. the old firewall is removed and found the PDF that shows Chad's firewall with the Pletty.
I think I understand correclty that the center off the Pletty is in the middel off the screws that holds it?
The engine I will use is a cheap China Axi copy ...if I work it works if not I maybe change it for a Axi ...
When you fly with a el. engine you use a bigger prop and remeber the old days with glow that you got change in the need for right thrust , but the rmp on the el.engine is lower do I need to make the right trust diffrent ?
With the YS I had 1,5 mm more that the nose indicated and that was perfect.
