RCU Forums - View Single Post - glow to steam conversion?
Old 11-17-2009 | 04:01 AM
monsterbombs
Default RE: glow to steam conversion?
ok i have found myself that i dont need to block anything.
yes it only spins half a turn. but with a flywheel, and no crankcase
pressure it will return to the top if the air/steam injection is timed.
i have fitted the flywheel and made a timed valve that will get air
or steam in just after TDC. one quick punch of gas. i have also drilled
out a glow plug and just need to work out the plumbing.
after sitting down with this little motor and blowing through a fuel line
into the spark hole ( compressor isnt with me) i reckon it should work.
i appreciate the comments
i will try to search what i can, more info would be great.
cheers again.
monster.
