RCU Forums - View Single Post - 12FG and Flaps Function
Old 11-17-2009 | 04:57 PM
Bax
Default RE: 12FG and Flaps Function
Normally, flaps are set up so that one endpoint is "up", the middle point is 1/2-flaps, and the other endpoint is full-down. So you set up the AFR as desired, and use the sub-trim to adjust he center point (1/2-flaps), and the endpoint adjustments to adjust the up and full-down positions.
