RE: Balsa grain direction
Thanks for all the replies. In this particular case my wing leading edge starts at 45* and then drops to 30* towards the wing tip. So the angles are not slight. I would like to use parallel to the spar but at this point I have yet to find a production kit that does not have the grain run parallel to the wing leading or trailing edge, not the spar, at least for an inch or two. There must be a reason for this.
