RE: RE:
I've never owned a tornado so I cant help you much with setup....and I doubt the t-maxx shocks will fit...usually as far as shock fluid goes I run the same wt in both front and rear (what wt to run I dont know, I would start off with maybe 40 wt)...one thing I do with my 1/8ths is put a bit more pre-load in the front then in the rear...seems to help my buggies fly more level....
as far as controling the rc in the air...give it gas and the nose will raise, hit the breaks and the nose will fall...
also the way you hit the jump has alot to do with how the rc will react off the jump...along with the pitch of the jump itself....
