You will be sequencing the gear and doors only, the brakes will be or could be on the right slider on your radio, ready to turn on or off at your command, ou could use the Ultra-precisiond valva ( AIR UP2 or UP3 ) or electrical from Jetronics.
Yes on the usege of sequencers ( main gear and doors ) then again they can be use to sequence many things.
http://www.tamjets.com/original/adva...200f6052d63547
