RCU Forums - View Single Post - ss props
Thread: ss props
Old 07-05-2003 | 06:41 PM
daddy/ben
Default prop saver
thanks Sierra Gold! I will give it a try,also I found that if you cut off the shaft right after the prop nut with a dremel, you will have less chance of bending the shaft. but the only thing bad about that is the rubber prop spinner wont stay on,oh well its only purpose is probably only for looks...
