RCU Forums - View Single Post - Help with Opti Kill Switch
Old 11-22-2009 | 04:04 PM
jedijody's Avatar
jedijody
Default RE: Help with Opti Kill Switch
That's correct, you must remove that channel from any mix you previously had it programmed into. Then in the Aux. channel menu program channel 5 to whatever switch you want to use for your engine shut off. If the it's armed in the wrong switch position, reverse it in the channel reversing menu.
