RE: AkroMaster CL-20
Great info guys again this is very appreciated!
well to sum things up ~ no plans in box only directions, one sheet with a few pic's and the basic glue & epoxy here.
the only thing i didn't like about the kit is when it came time to epoxy the hardwood (engine mnt) in place. directions state
"measure motor width and change position of the lower hardwood motor mnt to fit as necessary"
now on my kit the fuse has been already been cut for the upper and lower engine mnt. i guess what im getting at is ive would have like sig to leave the lower not cut out.
the reason is to fit a ENYA 20S the lower needs to be moved alittle.well i havent done this yet i thought about asking you guys on what your thoughts are on this. my options are cut/lower the fuse cut out for the hardwood to fit the enya 20S and add a filler
buy a wider piece of hardwood and cut it to fit the fuse slot then offset it to fit the engine.
did that make any sence?
the weight of the ENYA 20 S is 163 g = 5.74965 oz
the FOX 15 is 6oz <- is that correct?
