just throwing in a bit , the radio is actually very good its easy to bind easy to figure out
, good range and no interference , however for those on 80211.g it will interfere with your wifi but only after an hr or so then its ok also make sure you have a voltage regulater even on 5 cell nmh just in case , these units are sensitive to high voltage blue smoked on me at 7 volts so i bought a 20 buck voltage regulator and all is great you can use digital or analog servos , depending on preference and price 80 bucks give it a go the included receiver is even bound for you i give this radio an b + simply do to the fact it has no fail safe but you can always get an external and yes most work so long as there push button program
