RCU Forums - View Single Post - Ultra Cote bubbles
Old 11-27-2009 | 02:44 AM
Mr67Stang's Avatar
Mr67Stang
Default RE: Ultra Cote bubbles
Before applying the second layer spray windex on the bottom layer. Lay your second peice down and position as desired, it will slide easily. Squeegy out the windex while holding your peice in place carefully removing all bubbles (it wont move easily after this but will peel off like a static electric sticker). Dry the surface. If satisfied with the placement use a trim seal iron and make your placement perminent.
