RCU Forums - View Single Post - Build Thread-Scratch built for 8s
Old 11-27-2009 | 11:32 PM
dreadnaut's Avatar
dreadnaut
Default RE: Build Thread-Scratch built for 8s
The last thing I did before calling it quits for the day was to start working on the plug for the molded wing tips. I tack glued a piece of 1/8” balsa sheet to the wing tip, then sanded it to match the wing profile. Then I glued a 1/16” profile plate to that, then top and bottom pieces of flower shop foam using 45 min epoxy thickened with cab-o-sil.
ID:	1321878   Click image for larger version
ID:	1321879   Click image for larger version
ID:	1321880   Click image for larger version
ID:	1321881   Click image for larger version
ID:	1321882   Click image for larger version
