Poly Glue Removing
Hi guys...
I want to replace an engine mount made of wood in a Corsair to fit a bigger engine.
The wooden engine mount has been glued with Poly Glue.
I know epoxy can be removed by applying some heat.
Is there a trick to remove the dried Polyurethane Glue ???
There must be something strong enough to dissolve that glue.
Any suggestion is welcome.
Thanks !
