RE: Analog Servos and 2.4 GHz
A friend has the SD-10G, so I can attest to the fact that the 10 channel receiver does have this limitation. Unfortunately you do not have the option to run the receiver at normal frame rate, as Futaba does on their new generation receivers, also having the high frame rate on all channels is of questionable value.
Pete
