RE: Ultra Cote bubbles
Thanks everybody....I think I have the way to do it, at least over open areas. The pin ***** method worked perfectly. At first I used a regular T-pin. That made holes that were big enough to print through. A fine sewing pin solved that issue. It still can be an issue over a covered wood area, but very low heat, slow movement and patience rules here. I was told about another good method. Make the pieces with the normal 3/8" overlap and stick the whole panel's covering together on waxed paper. Now pick the whole piece up and apply it as you would a single sheet.
