RCU Forums - View Single Post - CA hinges on a P-51
Old 11-29-2009 | 10:35 PM
chocorrol
Default CA hinges on a P-51
<span lang="EN-US" style="font-size: 9pt; font-family: Arial; mso-ansi-language: EN-US">wel, Ifinally got my Top Flite P 51 and started the construction fun... Itook a look into Minn's article about CAhinges and Ifollowed all the instructions but one of the ailerons didn't pass the pull test and came off, the funny thing is that Imade the same steps on both ailerons and the other one seems to be ok since I tried to pull it very hard and nothing happened... now, my question would be how can Ifix this problem? The hinges slots are pretty big and Ithink Ican insert another hinge just in the same slot but just a little aside from the place Iglued the first one, could this work? I'm not good at making slots so Iwould like to avoid making another slot for every hinge.. the other thing is that in the good aileron there is a gap of about 2 1/2 mm between the aileron and the wing, is this gap to much? chould Iconsider cutting this other aileron and put robart hinges on both of them?
FYIIused the same CA glue and the same hinges sheet for both ailerons so Idon't think the problem could be the glue or the hinges quality.
Any suggestions would be appreciated.
Thanks!<o></o></span></p>
