RCU Forums - View Single Post - Venus II
Thread: Venus II
Old 11-30-2009 | 12:56 PM
  #1347
cappaj1's Avatar
cappaj1
Default RE: Venus II
ORIGINAL: gaRCfield
The wing bolt plate is on the other side of the wings, under the belly pan. It's there.
Having the space between the mounting holes lets the wing secure to the sides of the fuse, and not to a point in the center of the plane. This would give it a little more stability and ensure there is no gap between the plane and the wings.
Maybe you could try a new set of bolts? Maybe they got stretched or stripped? It shouldn't take much force to screw them down, and as soon as you start to feel resistance, stop.
Also, maybe check some other planes and compare the wiggle room? Just an idea, but I know my Yak has a little 'play' as do the SebArt planes at my field (I asked the same question with respect to my Yak).
Just thinking out loud, but like I said I don't remember anything out of the ordinary with that plane. I was shown to carry it to the flight line by grabbing a spot on the wings and feel that I really would have noticed something if it wasn't right. If you want to post a video I'll take a look at it.
Just went down to the basement to shoot a video of the 'problem'. Down there I had a bigger screwdriver than I use at the field. When I tightened the bolts, I think I got more torque on them without feeling as though I was going to strip them and when I went to try and move the wing, it only would move 1/32 or 1/16 of an inch forward or backward, ie. alot better than at the field. I think the problem was I wasn't tightening the bolts enough believe it or not. I'll post a followup if I notice anything different at the field next time and I threw the larger screwdriver in the field box for whenever that is.
