RE: Venus II
cappaj1, just to double check, when you assembled your wing, did you put that plywood wing bolt plate on before gluing on the belly pan? If you did not, then the nylon bolts would be digging in to the soft balsa wood of the wing. Hope what I typed makes sense. Let me know if you want me to elaborate.
-Chris K
