RCU Forums - View Single Post - 3D Flyer Servo Problem
Old 11-30-2009 | 05:49 PM
Jezmo's Avatar
Jezmo
Default RE: 3D Flyer Servo Problem
Yes, jzrf6c is right on the money. The built in BEC in the speed controll is not meant for the high loads these larger servos can draw. Depending on the current draw of your servos you can can use a UBEC as he mentioned (probably good up to about 5 or 6 amps) or a regulator which can be sized as needed.
