Hi Guys
finished today our super lumina set :-)
with over 90LM per side this MUST be the strongest lightset you can get...
lumen per watt lm/W ratio of luminous flux to radiant flux
so you give or take about 90 watts of power in one wing!!
power consumption : 350mAh per led give or take a 1500 mAh should provide a hour of light
Voltage needed 3,9 volts
the set i made contains 4 leds 6 lasercutted fake carbon plates.
as you can see on the pics it does look nice and clean
there will be a 3 wire servo cable attached with positve in the middle and the 2 leds fed by 2 x negative , so you can use 2 lights or 4 at a time.
example :
normal flight 2 leds , left and right
landing : all 4 leds
we are also working on a Front oleo landing light cut from 28ST alluminium , but this will be done right after we finisch the oleo,s...
so even if you are a scottsman you can afford this light set..
it is NOT possible to show you a decent picture when the lights are on , my camera goes bazurk and doubles the image.
and that is even when NOT pointing strait into the beam!
