RCU Forums - View Single Post - Hangar9 Tribute 36 arf
Old 12-04-2009 | 04:09 AM
3Dkunalud
Default RE: Hangar9 Tribute 36 arf
i recently bought one. Using and OS .40 SF for power. Hopefully, it will have enough power to prophang and do all other 3D aerobatics. What servos should i use. The manual states using any old standard torque servo will work. So i'm thinking the Hitec Hs-311?? Or do the servos need to be ball bearing servos. <div>
</div><div>Also, what do you recommend i do to strengthen the fuselage behind the TE. I heard many people complaining that Hangar9 didn't make that as strong as it should be.</div>
