RCU Forums - View Single Post - improved vibration
Old 12-04-2009 | 04:48 AM
  #39
barry wetherell
Default RE: improved vibration
OK, to shift the vibes, first we need to determine wether it is a rotational ,from the crank/cly or rotational from the spur driven starting boss, (in a conventional engine it would be called the crankshaft).
Is the viabrations a long the engine or across? perhaps a balance wieght on one side of the prop shaft could help, one would need to adjust it to fined the "sweet spot" or a additional wieght on the start hex, has any body had a go at this?????????
A.A.Barry
