RCU Forums - View Single Post - Hangar9 Tribute 36 arf
Old 12-04-2009 | 06:28 AM
Hibrass's Avatar
Hibrass
Default RE: Hangar9 Tribute 36 arf
ORIGINAL: 3Dkunalud
i recently bought one. Using and OS .40 SF for power. Hopefully, it will have enough power to prophang and do all other 3D aerobatics. What servos should i use. The manual states using any old standard torque servo will work. So i'm thinking the Hitec Hs-311?? Or do the servos need to be ball bearing servos. <div>
</div><div>Also, what do you recommend i do to strengthen the fuselage behind the TE. I heard many people complaining that Hangar9 didn't make that as strong as it should be.</div>
3Dkunalud,
Keep it lite! The HS 311 or 425 will be just fine don't spend anymore if you already have something that is similar... Now for strengthening, you may want to consider a layer of 1/32 lite ply lamenated to the bottom of the fuse from behind the engine to in front of the tail surfaces. But keep my first statement in mine keep it light! :-)
Other than that fly the hell out of it and enjoy!
Ed "Hibrass" Harley
