RCU Forums - View Single Post - Raptor 60 Blades
Old 04-01-2002 | 03:51 PM
bcourtcep
Default Raptor 60 Blades
OK.......I had my first minor crash... The Tail rotor blade had an encounter with the ground; yes it broke the Carbon blade and those nice little white gears.... At the same time the main blades struck the ground/grass... The Main blades were barely damaged; it just damaged the plastic covering on the blades, not a scratch to the wood. I looked at the main rotor blades and did not notice any splits or cracks... Also twisted the blades, No problem... My Question is can I cover the blades with monokote or do they have a plastic wrap to cover the blades, or do I keep these blades as a memory.... I did order a new set of blades just curious if I can use these later? Also I ordered the New Black Carbon Thunder tiger blades, 680mm..... Anyone know if they’re junk or A- OK... They were only 76$ is that to High? Appreciate your input... Thanks.......
Brian
