RCU Forums - View Single Post - 1st Gaser
Thread: 1st Gaser
Old 12-04-2009 | 04:21 PM
snuts
Default RE: 1st Gaser
Is that 5 tanks, or FLIGHTS. If it has flown, most likely no real surprises. If it has not been in the air, and if it has. A really good thurough ground/ range check before first flight. Not to scare you away at all. Sounds like the perfect first gasser. But once you get it do some reading on R/F induced enging noise, and range checking. Assuming it's 72mhz. But all that theory can be applied to 2.4ghz. Well your pumped, and you should be! Your comming home with your first gasser. The just of my caution is only preparing, and proper preflight checks, as if it was a maiden. Look into getting a local experianced Gas pilot to look it over, and make any suggestions.
Enjoy -Snuts-
