ORIGINAL: freakingfast
Those are the bearings you really want to use. The plastic retainers are far superior to the riveted or bent tab metal type.[sm=thumbs_up.gif] They wear better, have less corrosion issues, less drag and can take higher speeds. They are steadily replacing the phenolic cage type that were the king of high speed bearings.
Phenolic=plastic. Same thing.
