ORIGINAL: dignlivn
Hey Bill,
You need to wonder if the Engine was broke in properly.
Would he sell it minus the engine ?
Check for quality servos (high Torque) and ignition and
Rx batteries. Range check with A engine running at various
speeds (on the ground).
Check all hinges,pushrods and clevis's. Maybe install a NEW
Switch of quality also. What ratio of gas to oil was he running ?
You get the picture, pppppp
Bob
He told me he was running regular gas with Amsoil 100/1. Says if you use Amsoil it's okay to run 100/1 mix. He has several 33%ers that he flys with DA's. SO I assume he knows what he's doing. Nice plane. I sincerely hopes he calls tomorrow and says he got it running. Has dubro switches with built in charge jack.
