ORIGINAL: billd76
guy called, got it running, spark plug was loose he says, along with low igntion battery. Said once he tightened the plug and charged the battery it started on the first flip. Anyway, going to pick it up on Tuesday night. Of course I told him that I still have to hear it run. Weather has really turned south here, so I may have to wait a month or two before flying. That's ok. I want to spend some time scaling it out, do some research on the looks of the plane as it flew back in the 40's and make it nice and scale. Should be a good winter project.
I looked over all the control surfaces the other night and it does have hi torque servos. Should be good to go. Comes with a Futaba PCM Rx , which I can't use. Anybody looking for a PCM Rx?
I use PCMs!!!! I do send them into radio south to be checked out if they are used though.
