Ryobi problem
When you converted the engine from its former life what did you do about the priming bulb fitting?Some people retain the bulb but if you didnt the fitting on the carb must be plugged....As a weeder the engine uses a cheap rotating plate choke.....why didnt you retain it?It sure makes life easier than sticking your thumb in the carb.....
